Yoshi intake with stock intake....HELP..
jnegron
I have a 1397 12:1 comp, ported polished Carolina cycle head with .008 mill, .030 cosmetic gasket, standard base gasket.Right now I have the yoshi cams, is there any gain to install the stock intake on the exhaust with the yoshi intake? the cams are set at 105.
Any advice would be appreciated...
Thanks
Jose
You can go about 14:1 on your compression before you have to run race gas. Take out the base gasket and it will bump up your compression just a bit. Super unleaded will work fine.
PM back at you :welcome:
