Your input appreciated
Charles,stay away from any aerosol fix a flat stuff,just get a plug kit and a small compressor,the can stuff is corrosive and explosive.They make compressors small enough to carry or mount onboard.And congrats to you and yours.:)
the 16g co2 bottles add only 3psi a pop on my 22x11x9 ATV tires so you will need alot of them but they are small and light and can get you out of a jam. We have used the MSR style to pop a tire back on a rim, actually about 12 cartridges and some fancy holding by 4 guys on one tire, but we got our buddy back on the trail.
Thanks NJ!!
I have the plug kit, but now I need some compressed air or CO2 to inflate the tire until I can reach a gas station.
They make compressors small enough to put in the hump?
How many bottles does it take to fill the rear enough to get up to 30 miles.
<!--EDIT|Charlesbusa
Reason for Edit: None given...|1150311105 -->
Ba Busa only had 3 or 4 bottles to fill a rear up enough. But I don't know what size cans he had or what brand( I PM'd him ).
12 bottles!!! That ain't gona fit in the hump
Charles,you want me to send you one of those compressors? I think it'll fit inside the hump.???
Sure they will, they are the same thing you buy for BB guns, their only about 3"long and 3/4" in diameter. Like I said though not sure what it will take to fill a Busa Tire? My raptor probally holds alot more volume then a Rear 190/50-ZR-17. So 4-5 might be enough to get you out of a tight spot???
For $9 you can have your very own tire compressor with a few simple modz. This is what I have and packs nicely into the rear compartment.
For easy access to both tires I made an extension cord that is permanetly plugged onto the battery.
Dont forget to pack a tire plug kit along with your mini compressor !
Click onto the link below.
Motorcycle tire inflator for $9 at Walmart or any corner auto store.
Heres my jerry rigged mini  heavy duty walmart tire  compressor (largest model) along with a photo of the extension plug I made which is also used to connect my battery tender for extended downtime.
<!--EDIT|Rhythm
Reason for Edit: None given...|1150316109 -->
Charles I'm not sure if the one I have is the Motopump, but it is that style. It takes three cartridges to fill a 190/50 and is very easy to use. I would recommend that type or a on board compressor
A ten pack of cartridges is about the size on two cigarette packages.
hears what I carry and sell at the shop, very nice little unit and uses the battery tender plug also
I went to Wally World and bought a plug kit by Bell and the cartridges. It's small and fits nicely in the hump.
