Yes worked fine before tire change. The front brake issue has been there for a little while. Only happen when I use front brake hard when going 45+. I press it and the front shutters hard until I get slow enough it goes away. Rotors don’t appear to be warped
You can't look at a rotor and tell if it's warped, you need to mount a dial indicator to a wheel balancing stand, and check for any run out on the wheel and discs.
Make sure none of the rotor buttons are stuck.
Dirty calipers, like said above, can also cause brake shudder.
However, it sounds as if you could benefit from a brake overhaul.
New lines, stainless steel, if you don't already, rebuild both master cylinders, rebuild all 3 calipers, and replace the front rotors if need be, they are maintenance items, and they do wear out.
If you need new rotors, new pads are highly recomended at the same time, so only brake pad material gets imbedded into the new rotor, not bits or glazing on the pads from the old rotors, as brake pads bite metal discs well, but they bite metal discs with properly imbedded pad material better(series of 3 emergency stops from 60+mph to correctly 'bed' brakes).
Also, I would check my suspension set up, front And rear.
Wheel bearings and steering neck bearings can also cause shakes and shudder, so be sure to check them as well.
Too tight of a chain can cause a front end shudder(yes, you read that right), as if the rear dances from limited travel, it will easily upset an incorrectly, and in some cases, a correctly set front suspension.
