Yellow06busa
My busa is making some noise ab 300 miles after my rebuild I did a lot of work to it 1397 12-1 etc etc I think it’s an exhaust leak but I’m worried it’s cam noise what do you guys think
I’m gonna pull off the fenders and check if any bolts are loose I’ll lyk and thank you yellow looks great on the busa wish they were oem fairings thoLooks good, better than most....of course I'm biased....
It sounds like a very slight exhaust leak to me....
I have the same one, I pull the end out and that gives me a vacuum hose in both ears. I recommend the vacuum hose trick because most don’t have an automotive stethoscope like we do. They definitely come in handy.I use one of these….
Awesome for detecting unusual noises and the location of said noises.
Funny you say that about pulling the end out…I do the same lol, then I can home in on the location of the noise I’m hunting down.I have the same one, I pull the end out and that gives me a vacuum hose in both ears. I recommend the vacuum hose trick because most don’t have an automotive stethoscope like we do. They definitely come in handy.
Lol I’ve had that same reaction out of people when I put it around my neck.Funny you say that about pulling the end out…I do the same lol, then I can home in on the location of the noise I’m hunting down.
I’ve always used one of these while working with cars, but when I started at a bike workshop and pulled it, I got laughed at by the other techs… they’d never seen one.
They called me ‘the doctor’ lmao.
My dad did that as well and 99% of the time he was accurate and found the source of the noise...Lol I’ve had that same reaction out of people when I put it around my neck.
My dad used a giant screwdriver to pinpoint alternator, water pump, power steering pump etc noises, he would put his thumb over the handle end and put his thumb knuckle in his ear and the flat end of the screwdriver against where he thought the noise was coming from. I’ve done it and it works lol. Of course that was way back before he bought a couple stethoscopes for us, I still have my original one from 40+ years ago.
I recall one of my racing team mates had a GSXR Slingshot with a dry clutch....it sounded like the engine was going to fly out of it at any time......which in this case is probably just the "S" on the gas tank...
lol
