05 busa bogging hard at 6k rpm after motor swap
Pull off your stator rotor from the crank and check to see if the key way has broken. If it has it can rotate slightly and will affect your timing causing the computer to read incorrectly.
Update* I tried the fuel filter mod but it would not start at all after that. I think I drilled the hole too big. I took the hit and ordered the entire fuel pump assembly and the bike started instantly. It also goes WELL past 6k rpm now so that issue is resolved. But now it has a hard time running on its own without giving it gas and is boggy at low rpms. Next thing I’m going to try is new spark plugs since they’re really old and go from there.
Mine was doing the same thing. Changed plugs. Problem solved. Let me know. Interested if it fixed the problem. Thanks
