So pcv pti will dance around throwing my afr off? Or is it a location problem where the sensor is?
S2H: what year Busa are we talking about, Gen 1 or Gen 2?
Missed that, sorry! I still think it's a mistake. With only a 1:1 regulator he will be pushing on the duty cycles, when a better choice (IMHO) is to just get an FMU and run a pc without the hub. I've done hundreds of Busas this way, and they run great. Rob, the next time you are on a dyno, watch how mapping "tracks" or traces through the grid. You would think at 8 pounds of boost (just as an example), the cursor would hit the 8 psi column at around 6K (again, as an example) and then go straight up through the entire column, following the rpm. This is not what happens. The cursor will hit the 8 psi column and then "dance" between 6 psi and 10 psi as it makes its way up in the rpm. PCIIIUSBs with the hub and boost referencing graph do this, PCVs with the GM Map sensor do this through the grid, and Ecu editor does this as well. I don't consider this an accurate way of fueling a turbo setup. BTW, Microtech boxes do NOT do this, they are way more accurate, and as you have said repeatedly - secondary injectors would be the preferred method.
But what does goldenchild mean but no long pulls?
Frank if you go back and re-read his first post, he said he has s2k injectors, and has a goal of 250-280. It can work and has been done before, just need to run larger values in the compensation table of the hub.
Frank it's an 05.
I think he's talking about top end pulls and increased intake temps, etc.. You would want an intercooled setup if you are doing long pulls for 1/2-mile+ or you chance melting stuff. It should be reduced with E85 but still no guarantee, that's why most of the serious bikes run the RCC Ultra plenum, plus you can run more boost on pump gas. Since you are on E85 and it's not as tested (with bikes), you will find the limits...
Hope to see you out at TX2K14..
Doing a homemade kit will be on e85, 1:1 boost ref, s2000 injectors, etc. No intercooler or meth. Will be mainly spirited street riding.
Looking at the 16g or 20g because the price looks good. I was leaning towards the 16g because I don't know when I will have the money to build a motor. But then i'll be into it more for a bigger turbo when I do.
which got me thinking a 20g now and just live with some lag then i'll have room to grow when I want to. Is it just to much on a stock motor? when will it go positive? Anyone with experience or done it? I cant seem to find a thread, searching "20g" is to small.
thanks guys!
I hear someone's got a new fmu coming...
Someone definitely does.
No, you are both wrong, but somebody definately has some secondaries and a Microtech coming . . .
