orenp
I don't have much experience working on my Hayabusa, but lots on equipment. If you've got a hot start problem and you've got: 1) a good battery; and 2) good connections (ground, to the starter, and at the switch) -- the problem is probably the starter. Also, I always tend to suspect the starter when heat is one of the failure conditions. Batteries are usually fairly protected from heat (there's not a big difference in the 'micro climate' that they live in, cold versus hot motor). But starters live in a much more variable climate: when the motor is cold they're cold and when the motor is at operating temp they're hot. Simple and logical. Hope that helps.
