Cool..nothing but asphault for us.I'm thinking about running El Mirage dry lake. The first time out will be a stock Busa and work my way up through a few mods but staying in the production class. My goal is 204MPH.
To build the first sit on Kawasaki to get over that MPH would be really cool. Hopefully we have faith and perfect conditions on our side. I will keep you all posted.250 is an unbelievable speed. I hope you get it. Make sure to post your results.
I got it sir thank you for all the help. I will certainly give credit to you guys if we can pull this off. Ordered $3500 in parts today.Greg,
I sent you a working spreadsheet. The gear ratio I had posted this morning was completely wrong. The spreadsheet was recomending something more like an 18/34 as a starting point for you to hit 250.
GPW,
Where are you getting your information from, if you do get a larger turbo you have 3-4 great options.
Engine efficiency, head flow numbers, inlet temps at the throttle bodies, exhaust runner length, cam lift, valve diameters, runner volume, ambient air temp, corrected air, and several other factors have to be taken in to account.
I know a bad tune on a 35R had made 580 hp..Seb made 630 on his dyno..yes the turbo is really working however depending on many factors (also engine size) you can make more with less..higher compression and methanol will allow you to ditch the intercooler and run inlet temps under 100 degrees for your one mile time trial..
GL with whatever you choose.
John
Does the bike have a BOV and wastegate?
Post some pictures of the kit and congrats on the runs at Loring.
John
Case #1 Case #2 Case #3
For A Speed of ====> 232 MPH 232 MPH 232 MPH
We know it took this much HP ====> 393 HP 393 HP 393 HP
New Speed Desired ====> 240 MPH 250 MPH 260 MPH
New Required Hp for New Speed ====> 435 HP 492 HP 553 HP
