playing necromancer and digging up a dead thread. Basically stock 2003-no engine mods, no power commander, stock exhaust, stock sized sprockets, etc. I replaced the chain, sprockets, clutch plates, installed the Carpenter Clutch Mod lock ring with 3 stiffer springs and a slave brace over 3 years ago.
I've mentioned this before in other threads, but if I give the bike full throttle in 2nd gear then around 8k RPM it feels like the chain skips a tooth or I pulled the clutch in for .5 seconds. It is an incredibly fast, butt-puckering shudder and is not a fuel cut off. No issues if I slowly pull my way up the tachometer...no clue if it happens in other gears because I can't afford that kind of ticket!
With the bike on stands and idling in gear (no throttle), it sounds like she is "coughing"...lurching/bucking as if about to stall while idling in 1st and 2nd gear. There is a relatively loud "clunking" noise from the bottom of the engine (transmission area). I attempted to film it, but the camera just pick up engine noise. The lurching and noise are still present in the higher gears, but nowhere near as noticeable. The lurching and noise go away above 3k-ish RPM.
Engine idles fine out of gear and plows through the tachometer without issue. Unless someone has other thoughts/suggestions/input: the transmission forks/gears are toast. Baby it until I save up enough to buy an undercut/racecut tranny and billet forks, which are currently around $1300. Never planning to boost or beef up the motor...I can't afford that kind of continuous project
