4-way Flasher Mod
elsmooth
I am trying to mod my 03 Busa with the the 4-way flasher option. I have an 06 switch, but need help with the wiring option. The new switch has a couple of more wires and I don't have a wiring diagram.
Thanks
Wow I upgraded my 2000 low budget Busa to late model switches as to have the flash to pass and the 4 way flashers, But no documentation and its been so long ago that I don't remember..
Let me search this as MCMustang did a write up I beleave..
ps I remember it was easy though..
Also there was a download of the manuals for the GenI. They included electrical diagrams.
There are changes to the wiring harness between 00 and 06. But for most things, it will work just fine.
You should be able to do the mod with no problems with the link I posted up. Its the same one I used.. :thumbsup:
The link to page 2 references connectivity if you have a euro switch. I do not. I have a 2006 switch which has more wires than my stock plug. Wires exist in the slots that the directions indicate for you to use the 2 shorting wires from the old plug. Did you an 06 switch, if so what did you do with the orange/blue and yellow extra wires from the new switch?
True. However, the 4-way flashers don't work without some modifications. I installed the news switches some time ago, but never hooked up the 4-way flasher. The flash to pass works fine.
The switches I put on my 2000 model are off a '06 as well and mine work like they came on there from factory.. Hooked them up using post #2 link... :dunno:
