Hello all, I need some help from more experienced owners with this bike.
I just bought a brand new ( for me ) second hand 99 busa with 25000 km on board.
The main concern is the fact it lacks power it seems to go well @ 2500-4000 rpm if only a little throttle is applied but if I twist the throttle it makes a strange noise like not all the cylinders are working and it does not deliver, I was convinced by this when a friend of mine that bought my old bike, a 93 Suzuki RF600 r simply shames me on the road.
Then I decided to do a speed test:
in 2nd i was able to fully open the throttle and not much happens.
then up to 3rd-4th -5th where it would not rev any more and in sixth with full throttle open it will slowdown to around 180.
Another issue is that it starts kind of hard when is cold, I believe that only 2 at best 3 cylinders are starting then after 1-2 min it seems to smooth out.
Also connected to all of the above seems to be the fact that is overheating, I drained the old cooling fluid yesterday, it was simply muddy, cleaned the cooling system with water and now for a few days or until I figure it out I am running on water I thing there is no point in putting in the engine coolant if it figures out I have to open the engine.
So any advice on how to approach the issue is appreciated
