mesmeralda
I am not sure about your choice of coolant. I haven't heard of the pros and cons of it, but someone else on the board said that the factory stuff, 50/50 mix, is really good. Personally I use engine ice and like I said it gets half way. I still believe it shouldn't get even that hot. This weekend I am going to drain the system from the lower hose and refill it with either engine ice or factory coolant. The last time I drained it I did it through the coolant resevoir hose. and then I will burp it correctly.
