A little nos help
From mild to wild,We can get it done!! $390.00
<!--EDIT|TURBO1320
Reason for Edit: None given...|1156390368 -->
I had a "sneaky pete" 25 shot dry set up. As long as you don't use it to much it should last a few shots. The best part was it was really hidden and with the hump open you couldn't even tell I was sprayin'.
The down side was that it did lose pressure quickly due to the small bottle size.
<!--EDIT|grabntwist
Reason for Edit: None given...|1156390810 -->
The grab rail on the other side can be cut off leaving room for two of those size bottles. I would paint them black and mount them there. I would rather have the stealth set up. Refills must be a pain in the arse though.
what all is included for this price and how does it operate on a wide open throttle or on the sensor or something else.
THE ULTIMATE IN NITROUS SYSTEM DESIGN AND TECHNOLOGY!
UNRIVALED list of standard features.
Billet pulsoid that will NEVER wear out.
Billet bottle valve body.
Billet valve handwheel.
SPRV fitted to valve.
Anodized billet parts.
Stainless Steel fittings.
NO purge required.
Lifetime Warranty.
24/7 tech support.
Parts Included:
Billet alloy Pulsoid with SS fittings and laser cut mounting plate.
2 ea. Jets (30 & 40 hp).
1 x 12oz bottle (shipped empty).
Microswitch w/ stainless steel mounting bracket.
4 ft. 4mm high pressure nylon nitrous supply line.
Backing nuts and olives for nylon line.
Venom injector.
Arming switch w/ aircraft style cover.
Electrical connectors & wire pack.
Fitting instructions & stickers.
Note Comes standard with 4mm O.D. high pressure nylon nitrous supply pipe that doesn't require a purge as internal pipe dimensions are flow matched and gaseous nitrous is kept to a minimum.
Note: This system has the potential to increase the power of your motor up to 40 horsepower with no other mods.
www.1320straightliners.com
NO purge required.
Lifetime Warranty.
24/7 tech support.
Parts Included:
TP1 activation switch.
Venom injector.
Note: This system has the potential to increase the power of your motor up to 40 horsepower with no other mods. www.1320straightliners.com
heres the info i got from the website it shows it to be 439.00 but i can probably get it cheaper
Bolt-on the ultimate sportbike performance upgrade for an additional 30 to 60 hp
The ZEX™ EFI Sportbike Dry Nitrous System is the most advanced nitrous system you can buy for your EFI-equipped motorcycle. Unlike other nitrous kits that require you to fumble with the horn button to engage the system, the ZEX™ EFI Sportbike Dry Nitrous System incorporates an advanced electronic throttle position sensor switch. This revolutionary switch monitors your engine’s throttle position sensor, programs itself, and once armed, activates at wide-open throttle. In this way, the ZEX™ EFI Sportbike Dry Nitrous System allows you to easily control the nitrous hit to help manage the power if the front tire lifts.
Engineered for superior fit, finish, and performance, the ZEXâ„¢ EFI Sportbike Dry Nitrous System is a complete bolt-on kit that includes everything needed for a clean, professional installation. Each system includes a polished 2lb. bottle, high-flow nitrous solenoid, straight-shot nitrous nozzle, electronic TPS activation switch, stainless-steel braided lines and even plastic zip-ties for an easy and complete two-hour installation. As an added bonus, the Hayabusa specific kit has custom bottle brackets that hide the nitrous bottle under the Hayabusa’s “humpâ€. For more information about the new ZEXâ„¢ EFI Sportbike Dry Nitrous System or any other ZEXâ„¢ products, call us at 1-888-817-1008, or visit us online at www.zex.com.
Features & Benefits:
• Tunable from 30-60 additional horsepower
• A complete kit that includes everything needed for a perfect installation
• Features a patented electronic TPS switch for perfect system activation at wide open throttle
• Allows you to easily “tune†the nitrous hit to help manage the nitrous power if the front tire lifts
• Fits all EFI-equipped sportbikes
i can get this kit for 390.00 shipped if anyone wants one, i am trying to get them to come down a little bit more for a group buy,
ZEX/NOS/NX and the rest of the Nitrious world use PARKER solinoids and then put there stickers on them,they were not made to spray Nitrious!! Ours are made to spay nitrious thats why we have never had one fail!!
(TURBO1320 @ Aug. 24 2006,17:flamethrowing:) ZEX/NOS/NX and the rest of the Nitrious world use PARKER solinoids and then put there stickers on them,they were not made to spray Nitrious!! Ours are made to spay nitrious thats why we have never had one fail!!
lol you know the part number?
