abs pump thread size / fitting?
steel @ pump M10 . Should be a 1.25 pitch being a a Japanese pump . Brembo is normally 1.0 pitch however they will make to spec of manufacture . Example gen 2 brembo calipers are M10 / 1.25
I did discover the brembo 1.0 when I swapped over m/c and my banjo bolts didn't fit..
Thanks, I wasn't sure what size, but now I'm getting closer. I think they're a convex flared fitting..
Thanks :beerchug:
