100 miles to a tank of fuel?
will not turn over?
can you smell raw fuel?.. pull the air box, cycle the ignition (do not try to start) look down the stacks and see if you can see fuel leaking out any of the injectors.. (may see a brief "spray" but should stop..)
check the oil too.. see if is is watery or gassy smelling
will not turn over?
