air box mod?
crawlinbusa1320
what is it?how do i do it? and does it help
I researched this a bit before deciding against it.. I ride pretty much only on the street and so I like having low end torque available.. The mod may make a few more total ponies but it will borrow them from the low/mid range (where I spend most of my time)..
If you are drag racing, it simply removes a portion of the airbox to allow a bit more free air flow at high engine speeds. This however lowers the velocity of the air going through the box at slower engine speeds. (can cause a loss of power at these lower speeds)
I have not been able to verify any of this but it is how it works on cars with 4 hole throttle bodies
i plan on street riding it but the bikes setup the DRAG RACE!!!! lol can't wait for next season sick of 10's on a 600 lol but i should probally have searched well any help on how to do this would be great
When I did the small box mod, it almost felt like the bike was more responsive and smother at idle.
Its not more responsive, and it got "smoother" because it got richer thus lost power.
How did it get richer if you are letting more air in?
Answer, because at low RPMs/speeds the air isn't being moved as it would at high speeds through those small RAM air tubes. When it does, the turbulence sort of chokes your box. This is overcomed as speed/RPM increases.
thats why you need the pc3 and proper map ..
couldn't agree with ya more.
https://www.hayabusa.org/forums/?act=ST;f=47;t=51277
