Alarm Help!
ThisFackinGuy
I have a 2017 hayabusa and I recently purchased a new Scorpio i900 alarm system. Having an issue with install!
I uploaded photos of the instructions and the final connector that I'm having difficulty finding a connection to.
I connected the red wire to positive and the white/blue wire to negative but I'm having trouble with the white wire w/quick connector and finding a 12 volt switched wire source and it can't be LED. anyone know the wire color for the license plate light?!
the blue connector unscrews to show a pin. I'm assuming the 12v switched power source i'm looking for goes in between the cap and pin is closed into it?
Thanks for all your help!
I have a 2017 Hayabusa and I recently purchased a new Scorpio i900 alarm system .
Having an issue with install !
that I'm having difficulty finding a connection to .
and finding a 12 volt switched wire source and it can't be LED .
Anyone know the wire color for the license plate light ? !
The blue connector unscrews to show a pin .
I'm assuming the 12 volt switched power source .
I'm looking for goes in between the cap and pin is closed into it ?
Thanks for all your help !
