Cruise Control Switch, HELP!!!!!
sk8snw8s
I'm clear with the wire connection for the pin connector, the pink wire and black wire. I need clarification with the white, blue and gray wire.
Looking for assistants on where to connect or not needed for operation.
Dip switch settings is need also on the 250-1223 Rostra unit.
Here is a link for the switch installation, looked over it but I'm stomped on the connection of the white, blue and gray wires.
Thanks
www.audiovox.com/manuals/owners/250-3592-3593.pdf
I might be able to help with the switch settings if you have a link to where I can view them online?
(sk8snw8s @ Apr. 09 2007,10:15) Thanks for the help 05BusaLE. I have the 06BusaLE.
Here is the link for the cruise control pdf. I have the Ultra Cruise Control
The dip switch settings can be found on page 7 of this installation manual.
http://www.rostra.com/cc-250-1223-intallationmanuals.asp
You are going to have to play with the dip switch settings to get them right. I'd start with:
1 - on
2 - on
3 - on
4 - on
5 - on
6 - off
7 - off
8 - off
9 - off
10 - depends it you are using the magnets or the biks speedo signal.
See how it behaves and adjust based on behavior according to the suggestions in the manual.
