Rusheriv are still trying to figure this issue out with his cruise control, I think we may be on to something now. Those of you that have done this, feel free to chime in.
Problem: The servo will not engage and take control of the throttle when being set.
Possible solution: Right now he has the purple wire connected to the relay, then connected to ground for the tail light. I am under the impression that a ground connection to the relay will disengage the cruise control, giving the symptoms that he is having. I suggested splicing into the brake signal wire which is 0v when the brake is off, and 12v when the brake is applied.
This solution goes in line with post #25 by Captain. If you look at the directions for hooking up the purple wire, it states just what I have indicated above.
Your thoughts?
Your thoughts?
