Decided to redo my tail on the cheap. I purchased a taillight off ebay for around $25 shipped it's very bright and has built in license plate LED's as well. I had a scrap piece of steel and used the old bracket inside the stock fender to make a template. I was originally going to weld on blinker light brackets but changed my mind because of time restraints. I simply bent a couple pieces of aluminum into "L" shapes and mounted them on. I did grind them down so they followed the contours of the blinkers on the bottom and it turned out pretty good for now. Anyway it was simple enough and cheap to do. Here's a couple pics.
