Another speedohealer installation
kml
drilled four small holes...
cut a small piece of foam...
placed it above the ECU...
set the control box on the foam...
and zip tied the box to the frame rail.
It's out of the way and is easily accessed under that plastic thingy.
cheers
ken
Very nice!! I ended up doublestick tapin' mine under the seat...
that looks better!!!
I was going to put it in that location, but I upgraded tool kit...
and there wasn't room...
otherwise that's where I would have installed it.
cheers
ken
(kml @ Feb. 27 2007,11:13) I was going to put it in that location, but I upgraded tool kit...
cheers
ken
Now that is a lot of tools!!! My boot is getting filled with electronics, adding a GPS locator and then a power source for my cell phone.
I did it the lazy way and put the cell phone power outlet in the tank bag by connecting two, two prong trailer plugs with inline fuses to the battery...
They come out between the seat and tank...
connecting to another plug with a switch wired inline that passes thru a machined aluminum plate into the tank bag..
and it all connects to a female cigarette plug inside the tank bag.
looks like this from the outside...
it allows me to charge the phone in the bag (or whatever I want) and connect a electric vest to one of the first set of plugs. As for GPS I'm still using paper!
cheers
ken
Nice job,Ken, and where did you get the pwr outlet adapter attached to your tank bag?
Hi Rhythm!
I just took a two prong plug and a cigarette lighter extension, cut the ends off and spliced them together. I got the idea from this kit.
http://www.powerletproducts.com/products/ptb.php
But I thought, "hey I can make that, why pay for it?" and to paraphrase you in a previous post "Ain't nothing wrong with caveman style once in a while."
Here's hoping you are still planning a trip to the Maritimes this summer.
cheers
ken
(kml @ Mar. 01 2007,06:45) Hi Rhythm!
cheers
ken
I was referring to the metal plate adapter on the side pf your tank bag, Ken.  Also, I wont be visiting (N.S. and NF) this summer. The summer of 08 is more likely when I will be heading up your way (Cape Breton) and across to NF.
Keep your knees in the breeze.
Oops... my bad, I just free handed a drawing with the dimensions of what I had in my head and a machinist whipped it up for me. He also made the bar end to fit the Napoleon mirror.
cheers
ken
(kml @ Mar. 01 2007,13:36) Oops... my bad, I just free handed a drawing with the dimensions  of what I had in my head and a machinist whipped it up for me. He also made the bar end to fit the Napoleon mirror.
cheers
ken
Schweet mirrors you got there,Ken.
Now how about taking a few more photos of your mad creation (bag power outlet). I may have an ideal of how I can make myself one using parts from a local hardware store.
Two giant aluminum washers, one with counter sunk holes, a gasket with a slit and the appropriate bolts.
Inside the bag...
On a unrelated subject, I hacked off the fender last night, turned the plate mounting braket upside down and ground it to fit snug under the tail light. By no means as sweet as your fiberglass fab job
but not to bad for a caveman!
cheers
ken
(kml @ Mar. 01 2007,16:08) Two giant aluminum washers, one with counter sunk holes, a gasket with a slit and the appropriate bolts.
Inside the bag...
cheers
ken
Good lQQkn out my brother, I appreciate it. Also nice job on the shovel (fender) removal.
