heat rings look good...can you check egt's at the header tubes with an infra-red thermal unit. Let the bike idle at 1500 rpms check and at 2000 rpms then check see how the temps vary between cylinder..caught a dead coil and injector using this method.
Oh SURE any excuse to not ride with me ey Dozer!
J/K..hope you figure it out bro, we still got some ridin to do..
Dozer, I admire you trying to trouble shoot this yourself vs. bringing it somewhere and having someone else do the work for you and then bragging about.
Let me know if you have exhausted all corners and need to spend some time at HPC.
Your buddies Turbo 1000 was no easy job, I am certain we can sort it out.
wtf is clean and balance of your plugs?you got to be kidding me...and why would you do that when new ones are 4$...while your doing that check your muffler bearing and pitman juncture too
