Are ceramic bearings better?
Professor
Hayabusa Immortal
Do you think ceramic bearings have less rolling resistance? Do you think you can see the difference?
I was pretty surprised about the difference
Here is a video I took. Click to save/view
First wheel is oem
Second is a Marvic with ceramic bearings and wave rotors. Almost 4 lbs lighter.
Identical tires.
OEM has an advatage of a heavier wheel weight adding to the "flywheel effect"
check out the results.
Wow!
A bit pricey...but they are much better than the standard bearings
May sound crazy but, you can tell the difference rolling the bike by hand in the garage. I really don't think it is because my wallet is lighter but I could be wrong.
I'd like to see the same video, but with ceramic bearings and stock wheel rotors.
I'm sure there better, but the question is "Is it worth the additional cost for the additional benefit you get?".
The busa is tough to move around the garage, but for the price difference, I like the exercise :-)
It would spin longer than my light wieght wheels. I can fix you up. Call Dave @ world wide bearing and have him send me 2 ceramics for oem wheels and I'll do the rest.
Worth the price? I doubt it. I "might" try to go to the Texas mile in the fall. No doubt there is something to be gained there.
Back to back on the dyno there was a 2hp gain swapping to the Marvic wheel with ceramic bearings. Tire weight the same but the wheel is lighter. How much was wheel and how much was bearing, I'm not sure.
