Avatar Help?  READ ME...
Re: Avatar Help?  READ ME...
* Register and Log in.
1. Click on "Your Control Panel" --Upper left of each page--
2. Select personal Info
3. Select Avatar options... oddly enough...
OK From here you will see a big ole list, select one you like (THAT ISN'T Personal to someone else I.E. Named) Or you can always ask.
Select the avatar you want then click the "Add this avatar to my profile" button.
---------------OR------------------
Select an Avatar from the Web Using a URL
Add your own Avatar to the list and use it. Give it a specific name or it's fair game for the board. Try not to duplicate Avatars...
Be certain Avatars are no larger than 64X64 pixels. 96X96 if your a donating member.
I know, pretty small so take that into consideration...
Enjoy!
Rev
<!--EDIT|Revlis
Reason for Edit: None given...|1137724285 -->
Test!:bowdown:
Re: Avatar Help? &nbsp;READ ME...
Tried saving the image as small as possible (5k) still won't work, tried uploading it to photobucket and it says it's too large now! :-(
