Skydyvyr
So looking at the diagram, here is how the stock single fan is wired:
Batt Pos --> Fuse#6 --> Fan --> Fan Relay --> Batt Neg
The stock diagram shows nothing else connected between the Fan and the Fan Relay, so a likely culprit is a short to ground somewhere in this leg of the circuit. On the stock fan, this should be a Brown wire with a Red stripe. Trace it from the Fan to the Fan Relay. If anything else (except for your second Fan) is connected to in there that is at least part of your problem. If there is a bare spot on the wire and it is coming in contact with any other metal part (or other wire) this could also be part of your problem.
As far as the second Fan is concerned, make sure that it is connected to the same leads as the first fan. It should not have it's own seperate ground or power supply. Wiring it with it's own power or ground would cause behavior very much like you are explaining.
The fact that the fans run with the relay removed pretty much removes the temp sensing circuit as a culprit since it is only connected to the fan(s) through the relay.
If you can take a picture of how your second fan is wired that might help with the troubleshooting.
One last question, are you sure that you have pulled the Fan relay and not the Turn Signal/Side Stand Relay?
To answer one of your other questions, yes, the fans running for an extended time could certainly drain your battery.
--Sky
--Sky
