Truckracer
Picked it up yesterday (Saturday). Everything is fine, can't tell there was ever a problem.
That's what I told them when I was missing a bolt in my fairingDealer says parts on order..... Guess we will see how long this takes.
They didn't think it was funny when I suggested removing what I needed from the 05 LE on their showroom floor..![]()
So you guys dont have sealed/maintance free batterys? FYI a sealed battery cannot leak...the set-up guy could be retarded...there is simply nothing to fusck up.FYI, it is a lack of dealer prep. My leaked and shitted up the swing arm, shock, rear wheel, chain, and belly pan. All were replaced under warranty.
sealed batteries will leak if not serviced correctly from the start. FYI you are retarted for thinking that they could not leak.So you guys dont have sealed/maintance free batterys? FYI a sealed battery cannot leak...the set-up guy could be retarded...there is simply nothing to fusck up.FYI, it is a lack of dealer prep. My leaked and shitted up the swing arm, shock, rear wheel, chain, and belly pan. All were replaced under warranty.
they are sealed but they can be opened. Even if it was a sealed unit that you couldn't open presure is a ##### in a confined spaceSo you guys dont have sealed/maintance free batterys? FYI a sealed battery cannot leak...the set-up guy could be retarded...there is simply nothing to fusck up.FYI, it is a lack of dealer prep. My leaked and shitted up the swing arm, shock, rear wheel, chain, and belly pan. All were replaced under warranty.
