You gota be close man. Check the terminals, if they're corroded, clean'em, tighten'em and get ready to buy one. For the cost I would probably go ahead and stead of getting stuck 100 miles from home one day. Did you buy it new?(carolinadoublej @ Dec. 01 2006,18:55) I have a 2003 and still am running the stock battery....I am wondering the same thing.
No, didnt buy the bike new..The terminals are extra clean...But I do know that the original owner kept it in a heated garage hooked up to a tender..I do the same thing now. It charges and holds a charge very well...but I know that its days are numbered.(dadofthree @ Dec. 02 2006,01:43)You gota be close man. Check the terminals, if they're corroded, clean'em, tighten'em and get ready to buy one. For the cost I would probably go ahead and stead of getting stuck 100 miles from home one day. Did you buy it new?(carolinadoublej @ Dec. 01 2006,18:55) I have a 2003 and still am running the stock battery....I am wondering the same thing.
The reason I ask is that the battery may have been installed just before you bought it. On some batteries you can find a date. You might have a fairly new battery. Check it out.(carolinadoublej @ Dec. 01 2006,22:20)No, didnt buy the bike new..The terminals are extra clean...But I do know that the original owner kept it in a heated garage hooked up to a tender..I do the same thing now. It charges and holds a charge very well...but I know that its days are numbered.(dadofthree @ Dec. 02 2006,01:43)You gota be close man. Check the terminals, if they're corroded, clean'em, tighten'em and get ready to buy one. For the cost I would probably go ahead and stead of getting stuck 100 miles from home one day. Did you buy it new?(carolinadoublej @ Dec. 01 2006,18:55) I have a 2003 and still am running the stock battery....I am wondering the same thing.
(GIXERHP @ Dec. 02 2006,05:59) My stock battery didn't even make a month! And then the stealership screwed me and charged me for the new one!
Hmmmmm....Good Call...gonna have to check it out(dadofthree @ Dec. 02 2006,11:14)The reason I ask is that the battery may have been installed just before you bought it. On some batteries you can find a date. You might have a fairly new battery. Check it out.(carolinadoublej @ Dec. 01 2006,22:20)No, didnt buy the bike new..The terminals are extra clean...But I do know that the original owner kept it in a heated garage hooked up to a tender..I do the same thing now. It charges and holds a charge very well...but I know that its days are numbered.(dadofthree @ Dec. 02 2006,01:43)You gota be close man. Check the terminals, if they're corroded, clean'em, tighten'em and get ready to buy one. For the cost I would probably go ahead and stead of getting stuck 100 miles from home one day. Did you buy it new?(carolinadoublej @ Dec. 01 2006,18:55) I have a 2003 and still am running the stock battery....I am wondering the same thing.
