DevilDawg1
how do they get around the bracing on the arm?
You would have to pull the whole swingarm assembly. Like a chain without a masterlink.
I'm seriously considering this, anybody have any legitimate commentary on the product ?
??? I dont see why youd want a belt...
Form what I have read on numerous sites, the torque thing is a mute point, the new belts are more than able to handle the torque of a stock Busa and then some. The one from Scootworks is specifically designed for the busa.
I like the idea because they run smoother, last much longer and don't require any adjustment. Plus you are not flinging chain oil all over the place
And if this doesn't break a belt, nothing I do is going to harm it.
looks neat, wonder how much it costs?
There is a BIG DIFFERENCE in the amount of torque generated in doing a burnout and hammering 4th gear into 5th pulling into 150mph range.
I believe ?
As I see it.... Some guy, who spent just about as many years in school as I have spent on this planet, who wears a little white lab coat, and who Suzuki TRUSTS to make the right decision, decided that the Hayabusa needed a Chain as its final drive.
Who am I, when push comes to shove, to contradict that......
Just sayin.....???
If it weren't for the cost I would have gone belt years ago. Plenty strong and all the upsides way outweigh the downs. If you don't change your gearing frequently you would be fine.
IG not knocking you in the slightest, but ever seen a chain break...with the motorcycle still running on the other end? Chains break too and its nasty!
