rickneuhaus
You said in the other post that money was tight. You can save some coin and go with the EK ZVX2 instead of the ZZZ. I am running over 300 hp and I use the ZVX2 without any problems. Also if you go with the ZVX2 you can get different colors if that makes any difference for you.
Goldenchild has recommended the ZVX2 for a very long time, I took his advice two years ago and still happy. Nothing wrong with the ZZZ but if your engine is stock power then it is way overkill and more $$$$$.
If your replacing the front sprocket I would drop a tooth. It will make launching easier and quicker. It will drop the max speed from 186 to 175mph but is that really a big deal?
It is if you're ungoverned
13K
