Hi guys I’m after some advice on the best setup for a 2004 Hayabusa. The bike is used mainly for road riding with a trip to the drags weekly at street meets & bracket racing.
Currenly the bike has small airbox mod with pair valve removed and HMF high mount dual system. I am after the best quality- most reliable system available that will run 60-80 shot initially and maybe later up it to 100.
Based on advice I have received locally we have come up with the following system-
- NX Wet kit for Hayabusa #NX60007 with hump mount
- NX window switch #TPRS-001
- Schnitz 5 dial progressive controller # PNC-101 with Hayabusa wiring harness
- Schnitz Ignition retard unit #EFIR-13-02
- NOS Purge Kit #16030-NOS
- Bottle warmer
- Liquid filled NOS and fuel pressure gauges.
I intend running the system off the throttle with no button. And would want to ramp in at about 5000rpm in each gear.
Also I want to run an schnitz ignition kill box #1-0263 (not shifter) so I can flat foot change. Will the ignition kill work with the above system, will the NOS need to be shut off prior to the ignition kill?
Is this the best system available?
I am a complete novice when it comes to NOS and am relying on good advice to get the best possible system so any input and advice would be greatly appreciated.
Bruce Patterson
Sydney Australia.
- Bottle warmer
Bruce Patterson
Sydney Australia.
