BikeMasterBahrain
wired
wired
Looks like you loosened the compressor cover and turned it, or are the tabs are still on the bottom of the rad not allowing it to pull all the way back? I see a few things that make me wonder if you read over the installation instructions, they are on the CD that is in the zip lock bag of small parts, also a Yosh muffler will seriously hurt your hp output and will not work with mapping provided with the kit,
Richard
Vacuum line with tee and label in this pic is not installed in correct location,
Richard
on mine I had to remove the dump pipe flange and put layout die on it to put on flat belt sander, seemed like it was warped alittle, from welding or when it was cut, i was only able to get 5 lbs boost, thought I had a leak, after belt sanding it went to 7 lbs, plus I could see where exhaust gases were leaking out past flange. yours might not be that way, just saying easier to check it now
Nice post bikemaster. I enjoy watching your toy come together!
Richard
Do you have a picture of the turbo installed with the compressor in the right position? I would like to see how exactly it is fitted and where the oil filter fits in that picture. It will help to tell if this is the right place for the compressor cover.
Clamp on the fuel line to the right is a low pressure clamp, it should be installed on the small rubber elbow at the rear left of air box, the proper clamp is on the line, I can see it in the pic? Is there tread sealant on the brass fittings? The clamps for all the lines are pre-installed on them, you just had to loosen them off and slide them up to the fitting, and re-tighten. All this is on the instruction CD
Richard
I also do not see the riv-nuts installed into the frame for the plenum hold down straps, are you going to install the plenum straps?
Richard
