Sl1d3r
Hi guys i have a class 8 autograss car running a gen1 busa engine
Car started fine went to start again had no spark started looking into the wiring noticed crap loads of butt connectors and crapy house old connectors (makes me angry ) so i have redone all that properly soldered and heat shrink had a shite after market pump on changed that for orginal pump right amount of fuel going in now new sprad clutch turns over like a dream i get fuel and good cranking
He is my problem i have no ignition spark
Tip over has been bypassed some how not sure how tbh
Clutch switch has been change and looks like its been permatly earth which is poop and i will change due to normal map and power map and as far as i know all the over sensors would have been bypassed
All i did when car was sort of running is put it in gear it stalled and hasnt had spark since clutch cylinder has gone up the pooper dose the busa run a pressure switch of sorts in the clutch ??
In not dose anyone have any suggestions as i havent found away broken or crap wires yet also it has a brand new oddessy extreme race battery so all good there
Thanks for looking hope to get some advice soon
