ohzone
Have you checked that the fuel return line to the tank has not been crimped when the tank is lowered down as they changed these hoses in 01
(If I remember correctly) to a stiffer hose because of this problem,
If they line is crimped the fuel pressure in the system can be too high and cause rich running.
The 99s are prone to petrol filter problems and it is not unheard of the injectors getting partially blocked (especially the one closest tp the stand)
this will cause a poor spray pattern leading to fouling of the plug and poor running
