bleeding brake lines
(BA BUSA @ Apr. 08 2007,19:39)
(tangledclown @ Apr. 08 2007,15:52) how many have actually done this task?be honest!!
Been bleeding brake and clutch systems for about THIRTY years now...with or without a power bleeder
Same here. Well, maybe a little longer.
also used a mity-vac which took about an hours worth of work. since then installed some speedbleeders and what a difference
just open the speedbleeder a 1/4 open, pump the lever, add brake fluid as the level gets down to almost bottom and add more brake fluid. do this until the old stuff is out, tighten speedbleeder and your done
