bigoltool
Sorry, I had not returned to this thread in a while. As I have a Gen 1, the Banjo at the master cylinder is the only thing that's pertinent from mine here. As you can see I put the double banjo Bleeder right at the master cylinder, which is the high point of the whole system, and the most likely place for air to reside. You could of course put a single banjo Bleeder at each Caliper as well if you wanted to. Just make sure you buy the correct thread for the application as the Brembo parts are M10x 1.00 thread and the Master Cylinder is M10X 1.25 thread. Looking at the photo at the start of this thread it looks like you could easily add a bleeder banjo at each caliper to make your life easier. BTW I used hydraulic sealant on the bolts and also the bleeder.
