+1! it's never good to push a hurt engine any further you may end up causing even more damage.(SLEEPERBUSA @ Aug. 23 2007,22:55) You'll be LUCKY if all you hurt were the rings!
STOP riding it.
the bike was tuned for nitrous, i changed the jet the night before the shootout. it was tuned for a 40 shot, i found a jet that looked bigger and put it in, numbers were good but 72 shot dry, i knew i was pushing my luck, especially when i had greg run it about 6 times back to back, this time i am doin it right with the wet system and better pistons, and ill run it with the jets in it that it was tuned for!(GoldenChild @ Aug. 24 2007,10:32) a 72 hp dry shot just adding fuel,your stock pump gave up long ago and while on the dyno you should have seen that......a busa stock pump even if upped in the 100 % won't produce enough continued fuel for that kind of dry setup.You guys need to find some nitrous tuners...Did you go to a dyno after install or just stick it on and start spraying?the tuner if you did go to him should have had you upgrade your fuel system to spray that kind of spray...
I see,sorry that happened but nitrous with no fuel it has to eat something(rings & aluminum).There is a safe way to spray big shots of dry but you have to know what is going on...Buddies here are spraying 150 to 200 hp dry...(JIMMY @ Aug. 24 2007,15:01)the bike was tuned for nitrous, i changed the jet the night before the shootout. it was tuned for a 40 shot, i found a jet that looked bigger and put it in, numbers were good but 72 shot dry, i knew i was pushing my luck, especially when i had greg run it about 6 times back to back, this time i am doin it right with the wet system and better pistons, and ill run it with the jets in it that it was tuned for!(GoldenChild @ Aug. 24 2007,10) a 72 hp dry shot just adding fuel,your stock pump gave up long ago and while on the dyno you should have seen that......a busa stock pump even if upped in the 100 % won't produce enough continued fuel for that kind of dry setup.You guys need to find some nitrous tuners...Did you go to a dyno after install or just stick it on and start spraying?the tuner if you did go to him should have had you upgrade your fuel system to spray that kind of spray...
For the record DJ's motor is not broken..it pulled the same numbers at the Coleman Powersports HP shootout two weeks before ours. Since your writing a story thought you might want the facts. His bike never pulled the 308 horsepower the builder claimed it did. Neither did the other 400 hp bike the same builder did. Thats a whole other story. More of his business so I will mind it. Others should follow suit.(BA BUSA @ Aug. 18 2007,18:52)What I meant is you both have BROKEN motors...I heard that DJ's bike is way down on HP now(BA BUSA @ Aug. 18 2007,18:41)You guys sure must have had some fun(JIMMY @ Aug. 18 2007,18:37) yep, bike seemed fine afterwards, took it out this morning for the first time since then and smokin pretty bad, people actually put their windows up when i pulled up to them at the light, but it sounds fine and runs fineyou and DJ now have sick motors
Just heard that the DJ's bike was down on HP for some reason...whether it is a fuel, ignition, or a mechanical(GPW @ Aug. 26 2007,18:01)For the record DJ's motor is not broken..it pulled the same numbers at the Coleman Powersports HP shootout two weeks before ours. Since your writing a story thought you might want the facts. His bike never pulled the 308 horsepower the builder claimed it did. Neither did the other 400 hp bike the same builder did. Thats a whole other story. More of his business so I will mind it. Others should follow suit.(BA BUSA @ Aug. 18 2007,18:52)What I meant is you both have BROKEN motors...I heard that DJ's bike is way down on HP now(BA BUSA @ Aug. 18 2007,18:41)You guys sure must have had some fun(JIMMY @ Aug. 18 2007,18:37) yep, bike seemed fine afterwards, took it out this morning for the first time since then and smokin pretty bad, people actually put their windows up when i pulled up to them at the light, but it sounds fine and runs fineyou and DJ now have sick motorsunless you know more than reading forums.
I have not even pulled the pastics yet. Planned to dig into it in the morning. Honestly someone else needs to ride that bike at the next event. Think that will solve serveral issues.(BA BUSA @ Aug. 26 2007,18:15)Just heard that the DJ's bike was down on HP for some reason...whether it is a fuel, ignition, or a mechanical(GPW @ Aug. 26 2007,18:01)For the record DJ's motor is not broken..it pulled the same numbers at the Coleman Powersports HP shootout two weeks before ours. Since your writing a story thought you might want the facts. His bike never pulled the 308 horsepower the builder claimed it did. Neither did the other 400 hp bike the same builder did. Thats a whole other story. More of his business so I will mind it. Others should follow suit.(BA BUSA @ Aug. 18 2007,18:52)What I meant is you both have BROKEN motors...I heard that DJ's bike is way down on HP now(BA BUSA @ Aug. 18 2007,18:41)You guys sure must have had some fun(JIMMY @ Aug. 18 2007,18:37) yep, bike seemed fine afterwards, took it out this morning for the first time since then and smokin pretty bad, people actually put their windows up when i pulled up to them at the light, but it sounds fine and runs fineyou and DJ now have sick motorsunless you know more than reading forums.
problem...something is or was BROKEN.
Were you able to fix it?
Also I did not read about it...was told by a reliable source that he didn't know if he was going to be able
to run it in the next event the way it was.
Yes it can.....(JIMMY @ Aug. 27 2007,08:25) is the power commander ignition module capable of doing this using the pc hub with the different maps, or does the swith only change the fuel mapping?
