After getting the Pro-tekk pegs, I find my shifter is still fine but my brake lever is about a half-inch too high. I have to shift my leg to angle my foot to the top so I can use the rear brakes.
I do use my fronts about 80% of the time, however this is causing my foot to be half off of the peg. I'd like to lower it enough that my foot can be comfortably all the way on the peg and above the lever.
I pulled off the rearset and checked it out but it's a one piece design. I'd have to move the rear brake mechanism up in order to drop the front of the lever.
It looks like my options are to either carefully bend the lever down using a vice and rubber hammer, buy a replacement lever that's already lower, or figure out how to raise the brake mechanism so I can adjust the lever down.
Thoughts? Links to places that might have replacements?
Thanks.
Carl
Thanks.
Carl
