All i can say, Hmmmm BREMBO!
YES BREMBO! Thanks John! You opened my eyes to quality! At least in the brake department!
I have a Brembo MC off an R1 on mine and along with the HH sintered pads, gaffer lines and EBC rotors, my brakes are leaps and bounds better than stockAn old thread but still relevant, Im looking to fit a Brembo clutch aster cylinder but wondering if its actually worth the hassle compared to keeping the OEM version. Anyone else fitted a RCS16 or RCS 19? getting conflicting views even from Brembo! anyone fit to a standard bike? I am looking for a soft pull (spend a lot of time in traffic) I ride purely on the the road not tack or drag use. Any info much appreciated.
Its the clutch I'm looking forI have a Brembo MC off an R1 on mine and along with the HH sintered pads, gaffer lines and EBC rotors, my brakes are leaps and bounds better than stock
You are not going to get a "softer" pull but are able to adjust the lever engagement same as stock. I can easily do 2 finger stops with my set up.
Ah....I see..ignore my other post on your new thread then.....Its the clutch I'm looking for
To late I replied dammnnAh....I see..ignore my other post on your new thread then.....
Go for the 16 rather than the 19? does the 19 make it harder to pull in?Rcs16.. Do it
You'll love the difference
Sounds good this is the info I am looking for Next question how about the clutch switch so I can start the thing? I've read that theres a hydraulic switch available but can cause F issues.The 19 is way too big for the Busa slave.
It becomes wooden, stiff and doesn't quite work properly.
The 16 is a great fit. It just works.
