It will work, but it takes work, only mods you have to make is to the brick. you need to remove about 1 square inch from back rear corners to clear gen ll plastic. The hardest thing was the removal because the brick has a hard outside but soft lead on the inside, the soft material gave me the most trouble.Without plastic brick bolts up just like the gen l.Hope this helps
