Hey can you post pics of the repair. This is a standard problem with Busa's. I have the same problem in 2nd I just run it until the jolt then switch gears...NCpanther01.//(mike04busa @ May 21 2007,10:08) fix it yourself, cost me $550 4 gears 1 shift fork and saels/gaskets get a repair manual you will be all set.
I did not take pictures, If you know anything about mechanics, (I'am not telling just anyone to try this themself) make sure you are comfortable with tools, get a hanes manual, it is pretty good.all the gears I replaced were on the output shaft, look at all the engaging teeth on the gears to make sure none are rounded, shift forks are a good idea also.If I do another one I will take pics. once the eng. is out. any local takers need a hand ?? bring the bike over with your camera and we could fix it and set up a fix post.(NCpanther01 @ May 21 2007,21:25)Hey can you post pics of the repair. This is a standard problem with Busa's. I have the same problem in 2nd I just run it until the jolt then switch gears...NCpanther01.//(mike04busa @ May 21 2007,10:08) fix it yourself, cost me $550 4 gears 1 shift fork and saels/gaskets get a repair manual you will be all set.
I took pics when I did mine(NCpanther01 @ May 21 2007,18:25)Hey can you post pics of the repair. This is a standard problem with Busa's. I have the same problem in 2nd I just run it until the jolt then switch gears...NCpanther01.//(mike04busa @ May 21 2007,10:08) fix it yourself, cost me $550 4 gears 1 shift fork and saels/gaskets get a repair manual you will be all set.
Hey thanks and I'm standing by!!!...NCpanther01.//(magus @ May 22 2007,07:36)I took pics when I did mine(NCpanther01 @ May 21 2007,18:25)Hey can you post pics of the repair. This is a standard problem with Busa's. I have the same problem in 2nd I just run it until the jolt then switch gears...NCpanther01.//(mike04busa @ May 21 2007,10:08) fix it yourself, cost me $550 4 gears 1 shift fork and saels/gaskets get a repair manual you will be all set.
ill throw together a how to
like mike04busa said this is not the recomended route for someone with out tools and motor knowledge
either way they are going to replace it with a stock tranny...which will last you how long?........(Cadillac94Pimpin @ May 24 2007,13:56) UPDATE! Just brought it to the dealer. They said yes it is the transmisson and they want permsion to tear it down for $300.00. So if Suzuki said they wont cover it i have to pay the $300.00 if I dont have it fixed. They also said suzuki will sometimes come out there to look at it. He said they might not warranty it. They had a service bulletin that they showed me that said gsx-R customer complaining of 2nd gear slip under heavy throttle most often not a defect but poor riding. Sometimes confused with some type of surge. BS!! They know there is a problem. Any way they said my bike is stock so I should be fine. But there is a chance that it wont be covered. We really need to get something together on this against Suzuki.
