Buell Begs
silwarrior
Need some help on this... I need to go down further on the gear shift. I am down as far as I can go with the shift arm w/o touching the exhaust. Do they make a shorter shift rod?
I looked under the exhaust on the factory converter location,
You'll see where it bolts to the lower frame, I used three stainless washers as spacers and it lowers the exhaust tips just enough to get more adjustment for my shifter...
It does slightly touch when I actually shift but not when in gear and the shifter is at rest...
Same as me, it helped when I did the washer trick...lol...
Well, it's kind of in the way but not really,
I use the kickstand as a guide, My foot hits it and I just rub up against it for now...
I started a topic about finding a nice black kickstand that maybe wasn't to arched that I could replace the factory one with...
Jury is still out on what I am going to do...???
Hey Dude.. i assume your trying to adjust the shifter since you fit the Buell Pegs?
If so, they can be a bugger to get seup - the instruction say to twist the lever around on the peg, but i didnt need to do that. If you play around - it will fit without need for any hardware mods... you just gotta play :)
Jza
