Dopey
When u tested the stator leads did you first check that none of the leads had continuity to ground?? I've screwed myself a few times not doing that and had voltage coming from the stator but it was still shorted to ground of course in those cases its usually but not always a situation of the battery dying over night not while running. What was your a/c voltage reading from the stator?Finally had a break in the rain while I was home and did some tests. I believe the rec/reg is the issue even though I measured good and equal continuity from the plug.
I am getting increasing AC voltage from the 3-wire plug directly off of the stator as well as the plug that goes to the reg/rec. New stator is definitely working! The only DC voltage I get is from the battery, which runs the bike until it cuts off at 12.5V or 12.7V due to the BMS system in it.
@TallTom I removed all fuses, cleaned up the contacts with sandpaper, and reinstalled only the "main" fuse by the battery+ignition+fuel. No change, but great idea to test.
Since I paid big bucks for the lithium battery, I am looking at getting Rick's hot shot reg/rec specifically for lithium batteries unless anyone says otherwise.
