CorrodedAlien
Continental Force MAX... on my second set, last and stick, and... less $$ than most others
+1Continental Force MAX... on my second set, last and stick, and... less $$ than most others
I know and have seen lots of bikes with 2 different brands of tires on them and they all ride well.How much different will the busa run with two different types of tires? The front tire is perfectly fine and has quite some life still left to it. I'd hate to spend the extra $ for a front tire and to be honest with you guys with the holidays approaching my budget is looking pretty tight if you know what I mean. Should I then buy another bridgestone?
thanks
and how you do it? I`m ready to learn something new..oem tire 13000 km![]()
I do wheelies, hard accel, two up etc
a good rider can ride hard without killing the tires
unless you are drag racing
totally disagree. each tire has its own triangleation(shape) when i put a new power on the rear i had a battleaxe still on the front. i noticed that i had to really dip the front to keep up with the rear. \\\just my opinion.I know and have seen lots of bikes with 2 different brands of tires on them and they all ride well.How much different will the busa run with two different types of tires? The front tire is perfectly fine and has quite some life still left to it. I'd hate to spend the extra $ for a front tire and to be honest with you guys with the holidays approaching my budget is looking pretty tight if you know what I mean. Should I then buy another bridgestone?
thanks
+1. If you have your tires done at a reputable shop, they will not mount different brands front/rear. You can mix some different models from the same manufacturer, such as a BT56 on the front and BT020 on the rear.totally disagree. each tire has its own triangleation(shape) when i put a new power on the rear i had a battleaxe still on the front. i noticed that i had to really dip the front to keep up with the rear. \\\just my opinion.I know and have seen lots of bikes with 2 different brands of tires on them and they all ride well.How much different will the busa run with two different types of tires? The front tire is perfectly fine and has quite some life still left to it. I'd hate to spend the extra $ for a front tire and to be honest with you guys with the holidays approaching my budget is looking pretty tight if you know what I mean. Should I then buy another bridgestone?
thanks
now riding same tire , but with dif compound
(shoft, medium,hard) is a diferent story. i liked a softer front with a medium rear.
It isn't wise to mix radial and bias tires. As long as they are BOTH radial or bias it is OK.How much different will the busa run with two different types of tires? The front tire is perfectly fine and has quite some life still left to it. I'd hate to spend the extra $ for a front tire and to be honest with you guys with the holidays approaching my budget is looking pretty tight if you know what I mean. Should I then buy another bridgestone?
thanks
actually I don't know, it never happened to me before.and how you do it? I`m ready to learn something new..oem tire 13000 km![]()
Really? Aren't those softer compounds than the Sportecs? I do plan on going with those (Pilot Powers) for track dayz.Michelin Pilot Powers = 4200 ( Best )
If you are looking for a good track day tire, I know a place that still has sets of the M2 Michelin Race for $220.I do plan on going with those (Pilot Powers) for track dayz.
