The Big Red One
Ever since new I've noticed my first gen busa runs WAYYY better some days than others. I ride around 4500-8000 ft in elevation. Its always been soft in the acceleration department from the elevation. But some days it'll run like a raped ape and others it just seems to sit there when I twist the throttle. Last night I went for a ride up to an 8000 ft peak than came back down to 4500 feet. After I came back down with an empty tank at night it wouldn't lift the front in first under power. After I shut it off and filled it up at a 7-11, then started it back up, with a full tank I couldn't keep the front end down under power in 1st or 2nd. It was such a change I had to re-adjust my throttle control, it literally felt like it gained 30hp....huge huge huge diff
Its low miles and runs perfect...never had any probs with it. I've always just figured the elevation was killing alot of power. But last night it ran stronger by FAR than its ever ran. Shutting it off and turning it back on must of reset the sensors after coming down so much in elevation. What could change the performance so much? It runs perfect so its not any fuel/spark probs. And I've never had any codes or warning lights of any kind. I wonder if the ecu is retarding the timing something ridiculous? A sensor malfunctioning somewhere? Or if I even have a prob at all? After last night I know it has the potential to run strong at my elevation....I just need to figure out why sometimes it does and sometimes it doesn't?
