'Busa true top speed
my front forks have been 248mph.
Where are you guys finding the space to make these runs?  I wonder how much land is covered to reach top speed, does anyone know?   I really want to try it on my bike but I will need to carefully plan it out because there are just too many troopers on the highways in my area.
Come down here to the sticks of Southern Illinois. Good wide straight roads, few cops, no helicopters, you do have to watch for deer though.......I saw an indicated 180 friday night comin home from the drag strip, I ran off and left everyone else in the group, couple of 98/99 liter bikes and a few 600's. Still had plenty on the tach, just started coming up on traffic.......
I HIT IT TODAY!!!! I will add another topic with pics and stuff, but here is the conclusion:
In FLORIDA... elevation - like a couple of feet
 temperature - high 70's low 80's, BEAUTIFUL day!
Pretty much stock 2005 (Carbon Fiber Yoshimura Bolt-ons and marble mod) WITHOUT TRE:
Indicated 185 - GPS about 164 (the speedometer only goes up to 185mph but the revs keep going up)
I hit the limiter at exactly 10,500 rpms... I held it there for a LOOOONG time.... about 20 seconds (with the revs at 10,500).... GPS Speed = 182 mph IT WOULD NOT GO FASTER!
I stopped on the side of the road, popped the tank, and installed Ivan's Smart TRE (the blue one):
MAX SPEED: 188mph GPS - at 10,800 rpms. it would NOT go above 10,800 rpms (a couple of hairs before redline in 6th gear)
Now, something odd I noticed... in 1st, 2nd, 3rd, 4th, and 5th, I could go PAST 11,000 RPMS (a little past the red line), but in 6th, I was still limited to 10,800. Ivan's TRE DID allow me to pass the 10,500rpm limit (when you hit it, you feel it... you feel the power comming in and out, in and out, and the rev needle stays dead on @ 10,500rpms)
Conclusion:
Restricted    - 182mph @ 10,500 rpms
Unrestricted - 188mph @ 10,800 rpms
Now all you guys can say what you want, but I JUST did this TODAY, and this is what I got... With stock gearing (what I have) I can't see the bike hitting 200mph (Unless you can go waaay past the red line). Also, it's not that my bike lacks power, because I was hitting the right RPMS... If I was lacking power, I wouldn't be able to hit 10,800rpms in 6th...  Therefore, with stock gearing, unrestricted, an 05 will do 188mph (OVER 300 KPH!!!!! IT'S STILL CRAZY!!!)
If you changed your gearing you would most likely be able to pull it to redline. What it sounds like to me is that your bike doesn't have enough power to push it through the air at those speeds to reach redline. If you went up one in the rear you would most likely hit redline and maybe get another MPH or two out of it. Where you wearing full leathers for this run? If not there are other things that can slow you down, say you were wearing jeans and they flapped around, well now you're creating more drag and this can hurt you.
As far as reaching 200MPH it depends on how you want to reach it. Many people say 200RWHP but I would think it could be lower than this. If you can hit 190MPH give or take with about 155RWHP bone stock I would imagine that 180RWHP and up would get you in the 200MPH area. This is also considering you have perfect conditions and enough space to do it.
Make sure you have at least 3-4 miles! I did it on a stretch of about 5 miles (I started pushing REALLY hard from 1st gear shifting at almost red line in every gear and held it for a REALLY long time 4+ miles). However, at about 2-3 miles I was already at the limit (Both with TRE and without).
The other thing is, even if I had a full system, or more power, I can't see how the bike would go faster because I was hitting an RPM limit at 10,800. The only way I can see more power affecting the bike is that I would get there faster, but I would still hit 10,800 and the wheels wouldn't be able to rotate any faster than that.
This is still REALLY fast though! I calculated it to be 84.6 METERS PER SECOND! That's almost a football field EVERY SECOND!
Because you would have more force (RWHP and Torque) pushing you at the same RPM.
You have to consider how many miles you have to get up to speed.
True 184mph in about a mile and a 1/2 and limited.
198mph with out the limiter with pipe tune and air filter, in about a mile.
You need above 200hp plus gearing and you will see 200mph in 9/10's of a mile
More hp is needed once you factor the wind and aerodynamics in order to hit above the 200mph mark.
BentValve, there is a great straight a way near Randle for speed runs or head over to the East side. I have done 180 plus in those locations around town is nuts. Will never do any high speeds where there are intersecting roads.
GPS are not accurate either everyone.
Need a good place to host a video. I could kinda give you an idea of what my mediocre Busa will do. It's downright slow compared to many on here, but.............
Internet Explorer users go for it, Netscape users may need a plugin
http://www.putfile.com/media.php?n=Nite-Run-II
Sorry about the camera strap, I'm gonna redo it.
Another .........Not topped out, but still cool.
http://www.putfile.com/media.php?n=HSO-3-II
<!--EDIT|bronc3
Reason for Edit: None given...|1115813704 -->
Wow, that guy held it for quite a long time, thanks for the link.
That guy would be yours truly. Another board member is in front of me in the daytime vid, I just don't like getting too close at those speeds in case someone slows up suddenly.
<!--EDIT|bronc3
Reason for Edit: None given...|1115818673 -->
