Re: Busa with Fuel Pump issue and battery is drained after being parked for a few day
The latest status so far: I disconnect the ignition switch to see if the battery will continue to drain while parked. So far, after 24 hours the voltage decreased by .01 volts, let me explain, I tested the voltage last night at 12.52 volts, this evening it was 12.51 volts. Typically, the bike will drain the battery in a few days. If the battery stays this way over the next three or four days; would it be feasible to say the ignition switch is the culprit. Give me some input.
No, this does not tell you the ign. switch is the culprit. It really rules out nothing, in fact.
I think you need to start from the beginning and work through your problem logically here. Forget anything you have done to this point and assume anything could be the issue.
It is quite possible both problems are related. Here is what I think what may be happening:
You have a charging system issue. The bike starts, it may even read the proper charging voltage. This does not mean you are supplying enough current to the battery to keep up with what the engine is using. (If even 1 strand of the wire supplying your battery is intact, voltage will read correctly. Amperage will be almost nil however) After 1/2 hour of riding, the bike starts to code up with injector codes. This is because your battery is run down so low that the injectors are not getting enough voltage to give a proper feedback to the computer. You stop, and the next time you use the bike the battery is dead. This is not from a drain, but from the last time you rode. It would be likely, but not for sure that you are seeing other funny electrical issues such as guages acting funny. You charge the battery, assuming a drain issue and it is fine for 1/2 hour, or a few days again, then the problem re-occurs.
Does this sound possible? Replacing the regulator for example will not help you if the connector is completely burned out, as they sometimes do. There are other issues that could give similar results..
Start from the beginning. Have your battery checked. Check your charging system per the OEM manual. The method to find a drain I mentioned above IS accurate and if there is a drain it will show up if done correctly....
