Jeff I was going to try that simple fix, as copared to pulling all the PAIR stuff off.
What did you use for a plug, and did you mes with the vacuum line from the throttle body as well?
What are you YAFM settings, H, M, L, and low speed setting?
Thanks for the info.
You will be styleing and smileing, come friday - Thanks.
