Ok Gents,Have an 08 BKing and it definitely has the bad gp switch and I can't afford to replace it right now.Been reading about the timing retard thingy and had a crazy idea.Do you think it would be possible to use a simple TRE and bypass the gp switch.I mean like use what ever size resistor it takes to mimic 4 gear and maybe use a dpdt switch to swap it to the neutral wire and back to the resistor.Also does anyone know what value resistor to use I have read its different from the hayabusa and yes i know how crappy tre's are but i think 4th gear map is better than the 6th gear map it uses by default.This will only be until i can repair it maybe a month or two.
