GNBRETT, looks like you were running all the right parts on your Buick.
yea it was a two year build. here is what went into it:
MOTOR
Don Cruz Built Girdled 109. (Very thick casting)
Solid Roller. (Grind is Secret to Don Cruz)
Forged Bottom End.
DLS External Oiling System
GN1"R" Heads With T&D Shaft Mounted Rocker Arms.
"Custom" Valve Springs.
Precision Plenum.
Accufab TB.
TA Headers. (Stainless)
Meziere Electric Water Pump.
TA Valve Covers.
BHC Balancer.
March Performance Billet 160 Amp Alternator.
JW Racing Breather Assembly.
Moroso Ultra 40 Plug Wires.
JW Racing Up Pipe.
RJC 4 Inch Stainless Exhaust.
JW Racing 3.5 Inch Stainless DP.
Accufab Clamshell Clamps.
PTE 71 MM HPS DBB 4 Bolt Turbo. (Ceramic Coated)
Remote Oiling System.
JW Racing Cold Air Kit.
RJC I-475 FMIC.
Dual SPal Fans.
Aluminum Radiator.
RJC Pulleys.
CSR Mini Starter.
TRANSMISSION
Otto Built Stage III 2004R (All Billet Hard Parts)
Lonnie Diers Electric Transbrake.
CK Aluminum Deep pan.
PTC 9.5 NL Converter.
Custom Steel Driveshaft.
Driveshaft Loop.
REAR END
Moser Axles with C-Clips.
Eaton Posi.
TA Rear Girdle.
Welded Support Baces.
SUSPENSION
H&R Adj. Upper Arms and Lower Control Arms.
H&R Sway Bar Welded To Rear End.
Varishock Double Adj. Front Shocks.
Varishock Single Adj. Rear Shocks.
Global West Springs.
Hotchkiss Front Sway Bar.
Savitiski Upper/Lower Control Arms
GNX Style Brace.
JW Racing Mini-Tub.
ECM
XFI With Traction Control.
Internal Data Logger.
Thumb Wheel.
BOOST CONTROL
AMS 1000.
Deadenbear Co2. (Custom Mounted in The Back Seat)
Tial 44 mm WG.
Tial 50 mm BOV
FUEL SYSTEM
Double Pumper in Tank.
Champion Billet Fuel Rails.
Accufab FP Regulator.
Razors Dual Alky Kit.
PTE 95 LB. Injectors.
FAST Fuel Pressure Guage.
New Gas Tank With Chrome Straps.
BRAKES
Wilwood Front and Rear Disc Brakes.
Hydroboost.
WHEELS AND TIRES
HoleShot Hole Star 15x10 Rears Polished.
HoleShot Hole Star 15x6 Fronts Polished.
Mickey Thompson 325/50 MT DR's In The Rear.
Mickey Thompson 26/8 Sportsman Radials up Front.
BATTERY
Braille (21) Lb. Light Weight Battery Mounted in Trunk.
