*ahem* you looking to unload them sir?I do have a set....
i have that body kit in fiberglass i had made from air-techNow that's a Beautiful BikeGet you one of deez!!
, anyone know where he got the body work! MElikes it ALOT
I can get the Carbon fiber bar ends now...how much did you have the shave off of them or hone out the OEMs for a the right fit???ok, air-tech makes some nice stuff, but what about the tail section
GPW? The bar-ends were never an issue to get. However the CF tubes were the issue to get...is that what your asking about?I can get the Carbon fiber bar ends now...how much did you have the shave off of them or hone out the OEMs for a the right fit???ok, air-tech makes some nice stuff, but what about the tail section
Sorry I can get the tubes will the fit into the OEM triple clamp?GPW? The bar-ends were never an issue to get. However the CF tubes were the issue to get...is that what your asking about?I can get the Carbon fiber bar ends now...how much did you have the shave off of them or hone out the OEMs for a the right fit???ok, air-tech makes some nice stuff, but what about the tail section
You can not make the OEM bar-ends fith the CF tubes - aint going to happen. Call me, might be simpler this way.
PM sent... and rejectedi have that body kit in fiberglass i had made from air-techNow that's a Beautiful BikeGet you one of deez!!
pm me if anyone is interested
Yes, the LP tubes will fit into the OEM triple clamp with no issues. What you will have to do is bore out the ends, I forget how much off hand, but depending on the bar ends your using, I think for mine they were about 1" down, and I shave off the inside to it would fit the bar-end...I beleive I had to bore out 1 or 2 mm all the way around. You will than have to cut the tubes to the length you want them...as the LP ones come about 1 1/2" longer than stock. You will than have to notch each tube so they clamp into your triple tree properly, the one bolt will clear, but the other bolt will not, just groove the tube so it looks like the OEM notch. You will than have to drill holes for you control housings. The left side is no big issue, just make sure the right side is done perfectly, otherwise any force put on the housing will not allow your throttle to function properly...yah it took me a few hours of scratching my head to figgure this issue out....lol. Anyhow, just a basic run-down.Sorry I can get the tubes will the fit into the OEM triple clamp?
sounds easy enough...Yes, the LP tubes will fit into the OEM triple clamp with no issues. What you will have to do is bore out the ends, I forget how much off hand, but depending on the bar ends your using, I think for mine they were about 1" down, and I shave off the inside to it would fit the bar-end...I beleive I had to bore out 1 or 2 mm all the way around. You will than have to cut the tubes to the length you want them...as the LP ones come about 1 1/2" longer than stock. You will than have to notch each tube so they clamp into your triple tree properly, the one bolt will clear, but the other bolt will not, just groove the tube so it looks like the OEM notch. You will than have to drill holes for you control housings. The left side is no big issue, just make sure the right side is done perfectly, otherwise any force put on the housing will not allow your throttle to function properly...yah it took me a few hours of scratching my head to figgure this issue out....lol. Anyhow, just a basic run-down.Sorry I can get the tubes will the fit into the OEM triple clamp?
Glad you got the info you needed - Yes it is easy.sounds easy enough...Yes, the LP tubes will fit into the OEM triple clamp with no issues. What you will have to do is bore out the ends, I forget how much off hand, but depending on the bar ends your using, I think for mine they were about 1" down, and I shave off the inside to it would fit the bar-end...I beleive I had to bore out 1 or 2 mm all the way around. You will than have to cut the tubes to the length you want them...as the LP ones come about 1 1/2" longer than stock. You will than have to notch each tube so they clamp into your triple tree properly, the one bolt will clear, but the other bolt will not, just groove the tube so it looks like the OEM notch. You will than have to drill holes for you control housings. The left side is no big issue, just make sure the right side is done perfectly, otherwise any force put on the housing will not allow your throttle to function properly...yah it took me a few hours of scratching my head to figgure this issue out....lol. Anyhow, just a basic run-down.Sorry I can get the tubes will the fit into the OEM triple clamp?
So... My next question would be... When I get the money saved up... Big bore or CF kit?Ben, you looking around 2000-3500 for the fairing kit, minus the tank depending on brand.
Big bore and lose 10 lbs...and your good to go.So... My next question would be... When I get the money saved up... Big bore or CF kit?Ben, you looking around 2000-3500 for the fairing kit, minus the tank depending on brand.
Wasn't that in a mag a little while ago?What the bike looks like now.
Oh... so now I'm fat?lose 10 lbs...and your good to go.So... My next question would be... When I get the money saved up... Big bore or CF kit?Ben, you looking around 2000-3500 for the fairing kit, minus the tank depending on brand.
